Great to know I'm not alone. As I've noted before, I don't have a big motor on the boat, and that causes the boat to be front weighted. I keep it uncovered and on the water. Rain water collects in the front. There also may be a crack there allowing water from below deck to seep up onto the deck at the front. I pump out the water from the boat as needed, starting with the water in front, then while sitting on the back, I vacuum water that drains into the bilge. The prior owner must have allowed a lot of water to accumulate as well, because I vacuum a lot of leaves and other debris. I know there must be a great deal of water in there, but I don't know the best way to remove it while the boat is on the water. I'll be pulling the boat out in the next few weeks, and should be able to tilt the boat back, at least some.
