1961 Johnson Sea Horse 75 hp overheating
Clippership821
Whole new pump...Water coming out the back.....Could something be restricting the exhaust causing overheating? Water inlet tube? I'm at a loss.
Thanks
HighTrim
Re: 1961 Johnson Sea Horse 75 hp overheating
When does it seem to be overheating, at WOT, idle??
Clippership821
1961 Johnson Sea Horse 75hp still overheating
Is it possible that the pump is functioning properly but water is not getting up to the heads. I just put in a complete pump kit and it seemed to be cooling fine. Water coming out the back and all. There is a lot of moss material in the water by the launch. Is it possible some of that could've got into the water intake? Thanks
tashasdaddy
Re: 1961 Johnson Sea Horse 75hp still overheating
possible, also the thermostat may not be opening or clogged.
Clipper those two 3/8" short hosesat the bottom of the heads carry the cooling water to the thermostat box. Open up the box and check the passages are clear and see that water flows thru the heads.
Those thermostats can and do break. I ran my '58 fat-fifty for years without one.
Clippership821
Thanks would it be a good idea to put a tell-tale on the top of number 1?
HighTrim
there is a very good tell tale sticky at the top of this forum by IWombat. Worth a read. I would clean the intake area and have a look at the t stat like TD said.
Clipper, I do not remember if those motors had any plugs in the heads that would serve as a telltale.
You could rig up some kind of plastic tee in the hose from the head to the thermobox. That would be a good telltale, althought it is only pressurized to 10 psi, if I remember correctly.
Evinrude Boater
My 64 Evinrude has a plug. I'm planning on installing a tell-tale.
