Darren Nemeth
- Dec 25, 2007
- 561
Re: 1962 Arkansas Traveler restoration
I could be wrong but the red wire thing is a on/off switch.
So I have to put a switch in there? At the end of the red wire?
I'm confused- tell me what I need to do with the red?
The yellow I understand- connect it to the positive on the fuse block.
what is an isolation switch? Like a toggle switch?
Thanks Mark. I noticed the extra info you added. Wouldn't it be un-powered if I just turn it off when not in use? Do I need to worry about battery drain when my uni-charger is putting out 20 amps?
I'm looking forward to your link
Link added to previous post mate.
Alot depends on the unit, does it still "light up" in any way or display time etc even when the unit is switched off?
When this unit is turned off, the clock will still display so I guess it will be pulling some. If this is the case couldn't I just add a simple two way switch under the dash near the radio to just power off the juice to the radio?
That's funny skibum!
Ok, I got alot done last night- I was up until 4am working on the electrical. I pretty much have everything done except the speedo because it's not here yet. I think I'm going to go ahead and order the tach also because I had to move the speedo over to the center of the dash because of lack of room because the speedo is 4" in diameter. So now I have some open space where the speedo was supposed to be so I think I'm going to go ahead and do the tach (2").
The other area I have issue with is the stereo hook up- I'm stuck right now. Check out the pics and the part in the video and let me know what you think!
[/IMG]![]()
[/IMG]![]()
[/IMG]![]()
[/IMG]![]()
OK- here are the other pics of the dash with the rotary steering in place- I didn't run the cable yet- I'm still waiting on the wheel to arrive.
Also, the stereo and speakers are in. All my electrical is done except for the speedo and tach. Although I have to undo everything soon before I sand, fill, prime, and paint.
[/IMG]![]()
[/IMG]![]()
The VIDEO
http://www.youtube.com/watch?v=W5y122X3jYc
Mick, I simply ran a switch on a power wire to feed my radio's yellow wire as well as the lights, bilge pump, and clock in the dash. everything else runs from the ignition switch. Now as long as my ignition switch and this switch are off there is no draw at all even iff i leave something on these 2 switches kill everything so I dont forget and kill the battery
