1963 Boston wailer 13 footer
eddy622611
Mickey,
I just finished reading all of your restorations . Thanks for helping me pas the time. Hopefully you will be able go out and enjoy them now.
Cheers,eddy622611
mickyryan
well i was on water today with the whaler, having a weird issue or several i haven't been able to grasp
carb clean and working well
timing checked it is spot on hi and low rpm as per manual
135 compression on both cylinders.
good spark on both cylinders.
1, why is rpm 2500 on muffs only but 1100 on water
sometimes it wants to stall sitting after about 3 minutes of running under 1500 rpm
will idle across water at 1500-2000 rpm for awhile
when trying to get it to take acceleration if i raise outdrive a bit it will take acceleration however if i leave outdrive down it bogs and stalls at 1400- 1500 rpm in gear
at 3000- 3200 rpm the boat sounded great harmonics were singing on engine but 3k seems awful low rpm for a outboard, tach might be off as i have been having issues figuring out exactly how many poles this engine has the book says 4 or 12 im befuddled!.at 4 the tach seems correct at low rpm.
appears to me this is a back pressure problem however i don't know what would be causing it.
i wondered if engine was sitting too low in water but water is about 9 inches from bottom of engine and it is spitting out of the 2 bypass holes for exaust just under the engine at top of the mid unit..
mickyryan
Are there any blue crabs left in the greater Palm Coast area ? Or are you still lubing the shaft ? :rolleyes:
found out last night a friend says my crabpots reappeared out on the lake he pulled em to see and they had my name on them so they been soaking for 3 years rofl!
sphelps
Might get some input over in the Merc section Mick ...I’m sure you’ll get it figured out ..
Glad he retrieved your traps for you .. I’m surprised they still had lines attached ! Lol!
kcassells
Who cares about the engine!!! Where are the crabs!:cool:
mickyryan
So i think i blew up the lil engine, but thats ok i got 3 others so im going to just rebuild one and not trust that a 30 yr old engine was not neglected or has internal issues , hell these do t even have a head gasket to worry about :) but this way i can do new reeds and know after im done it should idle correctly and have the power it should have
mickyryan
It started making a funny knocking noise lol i cant wait to tear it down and find the fail
mickyryan
wow , been a minute since i updated , engine wasnt blown had a old piece if reed lodged in bottom cylinder i guess broke loose and found another spot to get smashed lol , replaced pistons and rebuilt engine, she runs out great! Dropped crabpots in to soak for a couple days yesterday, and drowned a few worms, boat does 22 and then starts porposing badly so im guessing needs a wail tail on the outboard.... getting ready to start rebuilding the yamaha :)
sphelps
Micky I think I would try smart tabs first ..
Was you trimmed all the way down ?
mickyryan
this way i been running it i start trimmed all the way down and as it starts to plane i start bringing it up until mph stops climbing tap it back once and she flys until she starts poropsing about a half mile or so of top speed
sphelps
I had a hard time getting the mfg to stop porpoising .. I figured out I didn’t have enough angle on the transom . Added transom wedges and it solved the problem ..
