kfa4303
Banned
- Sep 17, 2010
- 6,094
Re: 1963 Johnson 18hp ignition problems - I'm stumped
Hi weezy. Nwcove is correct about the white hose. It's part of the engine's oiling system. Just leave it be. I would also remove the key switch wires from the system entirely for now as well. You can easily add a push button/lanyard kill switch link the one in the pic below after you get the motor running. I've used them on all if my vinatge OMC motors. They're cheap, easy to install, work great and add an extra layer of safety to the motor. They only cost about $10 and you can get them on amazon and other sites. For now, you can stop the motor by simply turning the throttle all the way down. That's actually how most old outboards were designed to be shut off back in the day. Once you get spark in your plugs, you can spray a bit or 24:1 mix into the cylinders, install the plugs, put the motor in a test tank with water filled up to about and inch below the main exhaust and try to fire her up. Once she comes to life, we'll move on to the fine tunning stage. Hang in there, you've almost got it. Good luck!
