1964 Evinrude 9.5
rogerwa
Re: 1964 Evinrude 9.5
The stuck shaft. I have not hit anything yet..
rogerwa
What do you secure the crankshaft with. When you turn it the whole thing turns over.
Xcusme
The weight of the motor (resting on the flywheel and towel) is usually enough resistance to the back and forth turning (giggling-if you will) of the driveshaft. You'll be turning the shaft only about 1/8 of a turn, or less, each way. You shouldn't be able to develope enough force with pliers to strip the broached crank shaft end or strip the drive shaft splines. Soak the shaft/crank junction with PB Blaster and let it do it's work. Your not in a race, this can take some time, but it should break free.
rogerwa
Thanks for the tips. I hope this works. AS it is now there is no play whatsoever. I've got other work to do so I will hit this a couple times a day and see what happens..
Motor Boater Bill
Giggling or jiggling? I think the giggling comes when it finally breaks free...<br /><br />...sorry, couldn't resist!<br /><br />I have also heard you can loosen the LU bolts about 1/8 inch (with the LU attached) and run the motor, switching between fwd and rev, in water. I have not done this myself so I can't attest to it.
