1964 Starcraft Jet Star Aluminum Runabout Project
  • Rustoleum Marine
    Votes: 19 41.3%
  • Interlux Brightsides
    Votes: 16 34.8%
  • Pettit Easypoxy
    Votes: 11 23.9%
  • Total voters
    46
Woodonglass
Re: 1964 15' Starcraft Aluminum Runabout Project
I don't seem to see vinyl lettering on zazzle, am I not looking in the right place?:confused:
You're right, MY BAD, They only make Bumper Stickers!!!! Sorry!!!
lakelover
No problem. The link I mentioned, I actually thought their prices were by far the best I've come across. They have 18 pages of fonts and the website is super-easy to use, too.
lakelover
Today I cut and drilled the aluminum channel for my transom cap. I'm looking for things to do while I'm out of 5200. Will be delayed again tomorrow cuz I won't have a car to go hunting for it. Two cars currently in the garage, the other two transporting the working people tomorrow!:(
I also cut out a board with a similar shape to put over my dash overlay so the pressure will be distributed as evenly as possible when I clamp & glue it. I'm putting off doing that to be sure the urethane is fully hard & cured. I also did some measuring and template adjustments for the aluminum backer plate I'm making. And laid out my 4 deck cleats and 2 bow chocks to get an idea for positioning.
Not very exciting or picturesque stuff, but every little bit helps.
Woodonglass
What glue did you decide to go with??
Woodonglass
That'll work. Hey, you mailbox is full!!!!!
lakelover
Dang. My mailbox must be a lot smaller than it used to be, I just deleted a bunch of stuff out of it a few days ago! Pfff.
Back to work deleting.
lakelover
Another busy but slow day today, but got the dash overlay glued in. It went pretty smoothly and I like the way it looks.
Before & after:
I have a couple pilot holes drilled to mark the steering wheel & tach. I'll worry about switches & 12v outlet later. I have a piece of angle aluminum to fasten aolng the bottom to make it look a little more respectable.
fstorm08
Looks good LL!
lakelover
I also put the windshield back on, this proved a little more involved.
I bought some Taylor windshield gasket for the bottom and had a heck of a time getting it on. It came in a roll curled up in a plastic bag and even after sitting out in the sun straight, weighted on the edge by a 2x4, it still wouldn't relax. Solution: had to tape it on every few inches and leave the tape on until it was installed on the boat.
I had also bought some new windshield brackets that I thought would exchange right into place, but while installing on the deck I discovered that they moved the windshield about an inch too far forward. I wanted to use the original mounting holes, so I dug out the original brackets and used them instead, even though they are pretty pitted. One had the bolt-protrusion broken off, so I had to cobble something up to go thru the plastic. Not all the fasteners I used are SS, so I'll be replacing them later. The deck hardware is laid out for positioning. It's beginning to look more like a real boat!
I had said I was going to reuse the original bow light, but decided it was too pitted, so I got one of the Perko retro style lights.
That gasket material is nice, but now I'm wondering if the windshield is original after all because its contour doesn't follow the deck very well in a couple spots and the gasket fits loosely, but is OK. Who knows. Maybe over time it will cook into place when the sun heats the metal up.
Other than the curl, the gasket is pretty easy to work with. Here's a little goof I made because something is out of whack. I mentioned earlier that I think a tree fell on this once and I had to spend a lot of time reshaping the frame, so that might be it.
And of course, the busted corner. I have one piece, but not the whole missing chunk.
jasoutside
That looks nice lake!:)
KellyC
Man that is one sweet water ride Lake, good work.
bananaboater
Ensign
Big time progress, good work.
lakelover
Thanks guys, now if I can just find some 5200 locally I can put the transom in. Might wait until HD is restocked, they charge about 1/2 what other local stores are charging for it.
Woodonglass
Wow!!!
Wow!
Wow!
Wow!
Great Job!!
ezmobee
It's not a busted corner....it's a vent :D
Boat looks great!
lakelover
I like that way of looking at it!
Wow!!!
Wow!
Wow!
Aw, cut it out, you're embarrassing me!:D:D
As I'm getting closer to finishing, I can look back and see a lot of stuff I screwed up or bought too much/not needed & wasted the budget on, but I sure learned a lot. Good thing I didn't know what I was in for when I started! :D
I just ordered more SS fasteners last night. Even though they ain't cheap, it sure beats the hosing you take at Lowes & HD for small quantities!! A great small quantity website with reasonable shipping is http://www.boltdepot.com/
Also just went to a different HD and got 2 3 oz. tubes of 5200 for $6.47 each, so today I can start getting the transom in order.
Woodonglass
"bought too much/not needed & wasted the budget on,"
That just means you'll have it for the NEXT project!!!:p
That IS a good price on the 5200. Thanks for the link to boltdepot. It went into my Knowledge Library.
lakelover
Re: 1964 15' Starcraft Aluminum Runabout Project - What am I doing wrong here?
I'm trying to cut my transom plate from 1/8" sheet aluminum using a metal cutting blade on a circular saw. Max saw RPms = 4600, blade rated for 7500. I'm getting kickback so bad that I can hardly make the cut. Everything is clamped down and I'm running along a straightedge. I tried adjusting the depth of the blade up a little so just past the teeth shows underneath and that didn't seem to make a difference.
Never cut much metal before.
:confused::confused::confused:
dcovey
If I remember correctly, a circular saw runs backwards, so try starting your cut with what appears to be the "back end" of the saw.
