lakelover
- Mar 26, 2003
- 4,390
Re: 1964 15' Starcraft Aluminum Runabout Project
Yes, that's 1/4" exterior plywood. Anything thicker and I don't think you'd be able to get the curve in there. My original floor was pretty rotten and came out in small pieces, but I was first able to make rough templates on big pieces of paper before removal. I'm pretty sure it was the original by Starcraft.
The floor's sealed with: 2 coats of epoxy, and then the underside and edges have Rustoleum primer and 2 coats of Marine Topside paint.
When I get finished, the top of the floor and the seat boards will also have primer and multiple coats of paint.
If you use flotation foam, I definitely recommend putting the plastic sheet over it to suppress the noise of any movement. Otherwise it squeaks like crazy.
As far as rivets, there are many places you can get them online, just google pop rivets and check out what comes up; broad head are best for the floor. Or maybe you have a Fastenal or similar store near you. The rivets I used are 3/16 dia. x 3/4 long. The broad head is 5/8 dia. You could probably get away with 1/2" length with the 1/4 plywood.
I just thought replacing the floor ply would make it a little easier on the feet esp. since I might be barefoot in the hot weather. I know the naked aluminum floor can be kind of painful if you step on the ribs.
Hello
I have been watching your prgress, you are doing a great job. I have a 64 jet also and there was no floor when I got it and Ive been using it that way but you have inspired me to put one in. Did you use 1/4 inch plywood? I know you were given the rivets by another member But where can I get them? Thanks
Quic
