1965 Starcraft Cheiftain
Status
Not open for further replies.
InMotion
Re: 1965 Starcraft Cheiftain
Right, Gluvit for the bottom (rivets and seams) I wrote the post poorly, I meant it was the next step after sealing the floorboards.
Does anyone know how much Gluvit would be necessary to seal the area from the cabin wall back, aprox. 8ft.
Would one quart do it or should I go for the gallon?
Is this the type of expoy product you are reffering to? http://www.pridemarine.com/index.cfm?category=10060|10075|10696&product=9893375&code=810395005166
Also you say I can use the expoy without needing any glass matt? I would prefer that if possible.
Thanks again to all.
Nope... here's the proper link for gluvit quart --- http://www.pridemarine.com/index.cfm?category=10060|10075|10695&product=9896953&code=Gluvit Qt
ezmobee
1 quart was just able to do my 18' so it should be more than adequate for you.
MichaelP
I also used 1 qt on my 18 footer just on the rivits. Paid $42 at a local yard.
CraigBarnard
Still waiting for my Gluvit and epoxy to show up so I decided to test fit the panels.
rheagler
Looking good Craig. Looking Good!
CraigBarnard
Anyone know where I can find a seat like this one?
Thats not $400.00. lol
barato2
i had all kinds of info for you
til i got to that last line.
i have the same issue....want offshore grade seats but don't want to spend >cost of boat. best compromise i've seen is the molded-plastic-back helm seats from Tempress, Wise and others....still >$200 each tho, without pedestal/hdwe. i may have to punt and go for crappy ones not made for salt water
jasoutside
Yup, what that dood said ^^^
I got a pair of these guys from lowcostboatingstore on a great deal...
CraigBarnard
Got some good leads on some seats.
Thanks everyone.
Now can anyone recognize what prop this is by the faded numbers?
Thanks!
CraigBarnard
Finally starting to make some progress in the assembly direction.
Last weekend installed some Riv-nut inserts so that I can bolt the floor down rather than rivet it in place.
I want to have the option of easy removal down the road if necessary.
This Saturday I sprayed some rocker guard on the sides above the shelf. I will be bringing the side boards all the way up to the top of the gunnels with long oval access holes. I think it looks better than an open shelf where all kinds of crap can accumulate. The black of the rocker guard will hopefully create a neutral look to the background.
Stuffed as much foam sheets as possible under the deck.
Laid down the expoy coated deck boards but bolting them down will have to wait for tomorrow.
Once the deck is down its back to more disassembly as I want to remove the cabin wall and replace it. I will be moving the door to the center while I am at it.
CraigBarnard
Well the riv-nuts didnt work out as easily as i had hoped.
All they did was spin inside the stringer without allowing the deck to tighten down.
Now I have to figure out a way of removing them so I can lift the deck board up and probably replace it. Oh well, Back to the drawing board again.
64osby
I just pulled this one from my boat, it might be available. Not an exact match, but an original SC. PM if thinking.
GLG fishing
Now I have to figure out a way of removing them so I can lift the deck board up and probably replace it. .
If you can pry up on the board that may hold the insert and allow you to get the bolt out.
Sometimes is 2 steps forward and 1 step back.
GLG
FishNmemories
Well the riv-nuts where a complete disaster! I would not recommend their use to anyone for any purpose.
Now I have to figure out a way of removing them so I can lift the deck board up and probably replace it. All due to the damage of those crappy riv-nuts.
Hi CB, just reading through your thread and I was hoping these riv-nuts were going to work out for ya. Looking at replacing the floor on my SS down the road and I thought it would be nice to install these riv-nuts. I'm not certain but I thought someone else had tried this process with better results.
jbcurt00
With an uneven (curved) surface on the inside of a rib, if you didn't use 1, would an air rivet gun have tightened the riv-nut better?
CraigBarnard
Got back at the boat this weekend.
Managed to get the deck bolted down with the riv-nuts.
Took 2-3 steps back then started ahead again.
Cut and fit the boards that run along the sides.
Next weekend I will be taking down the cabin wall and replacing it.
Then its time to install the carpet on the deck and sides.
CraigBarnard
Made some more progress this weekend. Removed the cabin wall and have begun to replace it with cedar boards.
More reassembly tomorrow. Going to lay down the carpet and install the side boards.
TundraRocks
Coming together nicely. What was done differently to get the Riv-nuts to work?
InMotion
Some nice progress there CB. I can really start to see it taking shape now. Nice wood there too... cedar?
CraigBarnard
Over the May 24 long weekend I made some more progress on the boat.
Installed the rug and the ski locker.
Side boards are attached to the "Z" channel and are ready to rivet down.
Next step boxes or some other method of seat supports.
Almost done!!
Status
