1965 Starcraft Dart restomod
DLNorth
MT,
That's the old style way of mounting the steering, and yes, our green SC has the same as yours.
But the "new" style attaches the steering cable to/in the tilt tube on the motor, as shown in the pic WM posted, and then there is a short connecting link between the two.
I suspect one reason they went to this is less interference between the cable/arm and splash well when fully tilted up.
(ours rubbed at one time)
The other is there is no extra bracket needed that mounts to the boat, ie; lower setup expense.
Dan
Watermann
Yeah the clamp on the transom is something to move away from if you have the tilt tube on the motor, it's by far a better set up and is still used to this day for the steering on new motors. I've not had a boat with an OB motor with the clamp set up, they've all been the current standard tilt tube set up.
MTboatguy
I have never had any problem with my boats and I have never had the tilt tube set up on any of them, but if it is a better system for most, then go with it, I have a tendency to not change things that are not broke and mine work just fine. If I have problems in the future, I will take a look at the newer system.
That said, I will stick with my statement, with either system, you should not have to be creative to make them work.
BCaron94
I appreciate the info on both ways it can be done. I’m going to use the tilt tube since I don’t have the clamp. It’ll all have to come apart shortly anyway since I’d like to replace the 2x material the PO used for a transom with some plywood, as well as seal some holes in the transom also from said PO.
Watermann
Dimensional lumber transom, oh boy, some people :lol:
They continued not knowing what they were doing and used a bunch of steel fasteners as well.
BCaron94
Right?! That was the first thing I noticed! The amount of holes in the thing is what’s killing me. I’m really debating riveting a thin sheet of aluminum just smaller than the outside measurements of the hull with a nice layer of 5200 on it.
