1966 Evinrude 18hp
CherokeeJohn
I have a 1966 18hp with a cracked gear casing, I can get a 1969 gear casing for $50. The question is will it fit?? It looks the same, is there something inside that is different? Also what do I do about a gasket since this is no longer available?
Same gearcase , change out both upper and lower.-----.----Most shops would have the seal between the halves on a 50' roll.----Or buy an 0-ring and cut to make that seal !!
CherokeeJohn
Thanks your a lifesaver! The previous owner was not kind to this poor motor. He even jb welded a homemade cavitation plate with a dozen sheet metal screws on it. I think there is enough drag from the screws to off set the benifit of the cav plate.
oldboat1
Are you talking about a "whale tail" that attaches to the anti-cavitation plate? Maybe a picture would help.
