BWR1953
- Jan 23, 2009
- 6,310
It seems to always go that direction when guys think they'll just do one job or another, full on rebuilds happen that way all the time.
Ain't that the truth!
Are you putting the Gluvit outside? I think most people just do it on the interior.
Gluvit is applied on the inside only, in the seams, keel valley and rivets in the field which all happen to be below deck. Are you wanting to paint the entire inside of the boat over the gluvit?
One suggestion I have when mixing the Gluvit is to use cheap syringes.
I've had no issues using gluvit and SE primer getting on it, mostly it was over spray but now that I think of it I did shoot it on the transom seams that had gluvit on them when I painted my transoms. Been a few years and no issue on my Chief's painted transom seams.
I think you're selling yourself short, if you have the abilities to make the transom and cut out the keyhole then why not make 3 tiny cuts in the aluminum to square it off into the bowling pin shape? Anyway I would opt for #2, they'll use a saws all and buzz out the bottom of the keyhole.
