I got it finally got it running! I picked up a car coil ( Napa IC12) and resistor(Napa FA76) - they are for a 1960's Ford many other cars and trucks. The coil has "for use with external resistor" printed on it. Not sure if this is ideal, but it seems to work.
Do you see any problems using it? (I also switched the Rotor with the one on my parts motor, and cleaned the points, started right up.)
one thing I noticed was that when I first primed the gas bulb, it didn't seem to fill up the glass sediment bulb-once it started, the glass filled up and I ran it for probably 1/2 hour. Remember that last fall the motor slowed down and went slower and slower until it just stopped.- the new coil seems to have fixed that, but maybe there is a fuel problem too?
Now I probably should start a new thread, but I was asked if maybe it over heated last fall, and that's why it stalled out.
I picked up an Ames Infrared Laser Thermometer, and after idling in a barrel for maybe a half hour, the # 1 and #3 cylinders read about 122 degrees F, but the #2 and #4 side ran about 155 degrees. Is that way too hot?
I have a video showing the water coming out of the motor exhaust- it doesn't seem like a lot, but it seems like it's about normal for this motor. what do you guys think (again it's 1967 80 HP Johnson)
I'll try to figure out how to post the video.......said it's too big- do I need to put it on utube?
