ezmobee
- Mar 26, 2007
- 23,767
Re: 1967 IMP Aztec -- Thoughts and suggestions for Rebuild maybe repower
All those darn fiberglass guys must be too deep in their own itchy projects to respond....so you're stuck with my information regurgitation
I'd go with poly is I was you. You boat was originally made with it and when used with the correct glass products (CSM, etc) it's plenty strong. Plus, as you suspected, gel coat doesn't stick to epoxy. You'll spend a LOT more money on epoxy. Heck I used it just to seal my deck boards and couldn't believe how much I went through. You using it will all those glass products would probably cost you a grand in resin alone. If you do still go with epoxy, ondarvr has pretty strongly recommended against thinning it and he's an expert.
