catbones
- Jul 15, 2012
- 319
Hi all,
So after few runs with my newly acquired 15 foot 1967 Starcraft Jet I'm deciding that I will put her away, maybe one more fun ride out but after that it's the garage. I'm thinking sometime at the end of September I will start getting her rebuilt to my best ability and funding. So I wanted to start a thread here and introduce her. I will also update this with few pictures.
Few things I don't like on her, is the fact of no closed off storage so new floor storage will be in plans. Dashboard will need to be redone and I will also be redoing the flooring. The motor a 1969 I think Johnson 33 will be reprinted to match exterior of the boat and I believe that will be either black or white. Right now the Johnson is white as all of them are. I also don't like the color of the hull and the deck was painted pretty bad too. I've got blue bottom and white top side. I'm heading for a firy red topside and black bottom. The thing is she leaks also a little so im guessing a rivet or something gone lose which is perfect if im repainting.
Seems there were quite the number of rivets on her too that someone used some caulking on which looks bad up close so i will replace that. The other parts that worry be are a few spots like two that look like big blobs of something, hope that isnt to cover up a big hole but on aluminum its fixable i undersand.
Few other little things will also be added if I have time like side walls to hide cables away and rewriting the entire thing too.
I will be going through quite the number of questions and answers, other rebuilt threads as I will need help specially when it comes to parts, paints and wiring this stuff up.
If anyone has start up suggestions or objections do let me know.
I guess the first question would be (I dont have a big space like acres of land or anything just a driveway) would you flip the boat or simply take it off the trailer and work upside down.. It's 15' so it's about 400 pounds I'm guessing, any other ideas of flipping this boat? I dont want to invest much into once of flipping a boat. I'm guessing I can put it in the front yard and flip it off the trailer then slowly pickup each side and put it back on the same trailer with the trailer having some kind of frame built out of wood? What you guys think.
Pictures following this in a bit.
