Re: 1967 Starcraft Jet Rebuilding
So, first is first, I had just a little bit time each day to start taking out the rusty impossible to take out bolts that hold my ribs and the main middle rib or whatever its called running across the bottom of the boat hull. Grinder and disc cut came very useful to removing these.
Now as you can see some holes after the bolts are gone, look pretty good and some are just rusty, banged up and doubled. So, cleaning and fixing will need to be done.
Not the easiest as there is a bunch of these, probably around 15 bolts all together. Anyways, at this time I'm waiting for two things.
1.) My Gluvit to come in so I can seal her up when I'm done replacing the rivets.
2.) Rivets, and this one I really need help. I hate to ask as I should be showing more of my learning then asking but don't want to buy a billion of rivets
So, that said, if I have a hole after a bolt that is double, meaning one hole next to each other makes it look two wholes connected together, is this possible to fill in with two rivets? or do I have to use JB weld and some aluminum then drill hole and pop a rivet?
Now, when it comes to rivets I will need your help guys, majorly. Any suggestions to what size of rivets (standard) size, grip, etc.. I should get. I know, diameter of the hole of the drill bit. I think it's 3/16 but what about grip and head diameter dome size, etc.. any suggestion from anyone here that has a finished project to what I should purchase.
I was looking at the following;
3/16:
http://www.rivetsonline.com/closed-end-blind-rivet-pr68asph.html (just going to use this for all purposes rather then switch between 1/8 and so on, one for all jobs and things) <---- Would this work?
1/4:
http://www.rivetsonline.com/closed-end-blind-rivet-pr86asph.html <---- waste of money or should I get some.
Sorry, I just been looking at rivets for a week and can't wrap my head around all the diagrams and stuff neither are my holes the greatest quality or round size to measure.
