cedarjunki
- Aug 23, 2007
- 472
Re: 1968 8-teen project
its really not as bad i made it out to be.....
finished the glassing and painted the bilge ready for the newer engine.
cleaned it up with the pressure washer and blew thru the 2 (steel)
welsh plugs. replaced with brass! noticed it need a new water shudder had to wait 4 days to get it. so i painted the motor, now its a cute redhead
even though it looks orange. i did odds and ends, anxious to put the motor in and hear it run....
finally got the shudder, installed it, slapped in the motor. aligned it, it was way off after refoaming, and a new mount glassed in! put oudrive on, slid in easy as pie for the first time i can remember.
started to raise it up and the pump acted funny again
got tired of messing with it and robbed the ss of hers. worked perfectly... picked up tools, put in fresh gas. about 20 minutes later told my kid to raise it up as i got the blazer and heard a loud pop....the reverse lock valve stuck and built enough pressure to blow oe of the cylinders apart
robbed the ss again lock valve and trim cylinders....
now it works better than it ever has! brand new lines last year so its good to go....hooked up blazer, pulled out of garage.... hooked up muffs and it fired right up! after sitting for a few years i expected to hear noisy valves or something but nothing.... ran perfect! that new shudder is very noisy though!
let it run about 20 minutes, the old man was tickled pink after all these years of having to yell over the knocking of the old motor. working between raindrops put it back in the garage started looking it over....dad asked if anything was leaking....ummmm well the rear main seal is dripping
i still need to paint the deck and finish my trailer before either can hit the water.............if it werent for bad luck i wouldnt have any right now!
sorry to hear about your woes.
so what happened? maybe others (me) can learn from the blues your getting.. hope your nightmare becomes a pleasant dream..
even though it looks orange. i did odds and ends, anxious to put the motor in and hear it run....finally got the shudder, installed it, slapped in the motor. aligned it, it was way off after refoaming, and a new mount glassed in! put oudrive on, slid in easy as pie for the first time i can remember.
