1968 Larson All American
coolbri70
No Title
calling it a day;)
coolbri70
No Title
the inner skin is back:D almost ready to pour;)
coolbri70
No Title
i think i will grind out the bubbles, fill them with mat and resin, then glass the splashwell back together before i pour the seacast. maybe i can get some done after work this week
sphelps
Resizing your pics would sure make it easier on the eyes ... I have a hard time seeing them even with my reading glasses on .. :D
coolbri70
just uploaded them, not sure how to resize:noidea:. i will have to look into that. don't even an option to edit those, only this?
coolbri70
IMG_19800106_204800.jpg maybe i can only edit my last post? think the forum is having issues?
coolbri70
so it looks like they have to be uploaded as attachments and i can only edit my last post? another upgrade?:laugh:
sphelps
A free photobucket account is the easiest way to post pics .. click the img tag then paste them in your post .
Nice BIG PICS ! :joyous:
coolbri70
i don't have photobucket:noidea:said i wouldn't do photobucket. also said i wouldn't have a computer:facepalm:, or be on the internet:doh:, or let a woman tell me what to do. maybe i should get a photobucket:indecisiveness:
coolbri70
poured some seacast today took all of 10 gallons, thought i was going to have over a gallon left but maybe the rounded bottom took more:confused:284.jpg 286.jpg 291.jpg 297.jpg
coolbri70
294.jpg 296.jpg i will have some grinding and sanding to do now, but it feels solid already:D
sphelps
Did you have enough to get to the top ?Kinda hard to tell from the pics .. You can order another gal and pour if you need . It does not make a cold joint ...
You sure there wasn't any holes in the bottom where it could have seeped into the bilge ?
Pretty easy process huh ..
coolbri70
well i grinded off the excess and i figured out why it took so much seacast my outer skin bulged out under and in above the 2x6 i used for bracing:blue: guess i should have put another 6 or 8 inches down:facepalm:. the place my motor bolts on is curved not flat. thinking a belt sander and some glasswork can fix it. so i will be sanding down the bump and building up the skin up top:rolleyes: guess i will be gelcoating the rear again. at least there is no flex:noidea:
coolbri70
i had just enough, well i went over the top about 1/4" had to grind some off, which took off the cap i tucked in. it didn't seep into the bilge, it bulged out on the outside where the motor mounts. not enough bracing.
coolbri70
ok i am testing new photobucket account, how do i post pics from there?
sphelps
In your P/B click on the pick you want to post ..It will show up kinda big . Over on the right you will see an IMG tag . Click on that and it will flash yellow copied ..
Then go back to your post right click and paste ..
