1968 mercruiser 120 single lever control question
wrfalpacas
I am rebuilding my side mount control hosing and replacing the 2 cables and I cannot find a replacement the shift interconnect switch (is that what it is called? and does anyone know where to get a replacement):confused:. I am talking about the wire that comes from the shift and throttle control and goes to the harness and ignition switch.
Bt Doctur
Re: 1968 mercruiser 120 single lever control question
Otherwise known as the "neutral safety switch" that prevents starting in gear.
May be no longer available
