1968 mercury 500 no spark
Ok installed new starter and she cranks great. No i do not have any spark. Where do i begin?
serial number on the motor is 2408947
Thanks Nick
Tassie 1
A good manual would help sort out that problem.
but the distributor and timing would be a good place to look
Have gone thru all wiring and repaired if necessary.
Is here a way to test the switch box?
Can i test the ignition coil?
Thank you Nick
merc850
If you have Tbolt with a Lightning Energizer (I am sure you do) here's an overview of its design and function.
Merc850 thank you
Finally something that looks familiar to what i have. At this point i believe i have a type II ignition system. If i understand correctly this system does not points and condensers. I kept reading about points and thinking i don't have nor do i see points anywhere in the system.
I also do not see a mercury switch or a tilt sensor which i have read about being an issue. One last thing when i looked at the manual the was posted on here i do not have a ground wire from my my magneto to the engine. Would this make a difference?
I guess this should narrow it down to the ignition coil or the switch box. Of course both expensive parts.
Hey thank you guys again for the help i will be in the garage tonight testing the low speed and high speed coils
Thanks Nick
merc850
No mercury switch. Yes you need the ground wire It could be a possible reason; I would remove the ignition driver by removing the 4 bolts that hold it and check the cap and rotor inside, the shaft has a blanked spline that makes it easy to reassemble it. There are no points and it will work without a battery.
Merc500
Removed the cap and inspected everything. all four poles and the rotor needed a good cleaning. I did notice that the rotor tip seems to be higher on one side than the other. Cleaned and reassembled but still no spark.
I tested the high and low speed coils and everything checks out.
Can i test the coil and switch box?
Thanks Nick
