I just picked up an older v4 85hp Johnson with a problem that I've never seen before.
When the engine is cold, the spark advance plate moves freely when pulled by the throttle linkage. However, after the motor warms up, the plate binds up so tight that it locks up the throttle lever at the remote.
I've removed the cable from the motor and the remote handle moves freely, so I know that the problem is not in the remote. After pushing the advance plate back by hand (very tight) the throttle moves easy.
I plan to pull the flywheel tomorrow and check things out.
I forgot to add that the motor start right up seems to run fine at wot, but after running for a while you can't pull the throtle back past 1/2 way. Not a real safe way to operate......
