1969 Johnson 40 HP - Reed valves?
Engine runs great, just came out of the shop. But when I have it full throttle it takes longer to get to full speed. A few waves and bumps and the engines revs a little a time. Good this be reed valves? If so, where are they?
tx1961whaler
Re: 1969 Johnson 40 HP - Reed valves?
No, if it runs great it is not the reed valves.
I don't quite get what the problem is.......
jbjennings
Ditto on both...
Just curious-- why do you think there's a reed valve problem? Reed valves serve no function past about 1/2 throttle.
F_R
Yeah, I went straight up when I read that. But when I came back down, I figure he means they can LEAK pretty badly and still run at high speed. But broken or missing??
jimmbo
Even leaky will cause a loss of compression in the crankcase so how would the cylinders get a fresh charge?
boobie
I've seen mtrs run with broken reed valves at WOT but wouldn't idle worth a darn. To much spit back through the carbs.
HighTrim
I have seen that exact thing a couple times as well.
Regarding the issue, is your prop hub spun?
jbjennings
Yes, that's what I meant. How the heck would one ever get it started if a reed valve was broken or missing. It would never happen. WRONGLY stated on my part. sorry OP......
jimmbo
I guess it could run on the remaining cylinders but probably like an engine that lost spark to one cylinder
boobie
If you have a 3 cyl mtr with broken or missing reeds in one cyl it will start and run at wot but won't idle. Been there.
Could there be a blockage in the fuel hose which leads to the gas tank? When it's at full throttle and there's a delay in response and than when I hit a wave or bumb, that will even jump the RPM's up. It's almost like there's a piece of junk clogging something up.
Some people have been telling me that. But if the hub is spun, I would probably still hear the RPM's witout the power. I am hearing RPM's increase with speed. Unless the prop itself throws out RPM like engine noise. How would I check/fix that?
tx1961whaler
You can check for a spun prop by drawing a line w/permanent marker across the center of the prop hub to the outer part of the prop. If the line on the center hub does not stay lined up with the outer part (under load) then the prop hub is spun.
lindy46
I'll bet you have an intermittant coil problem.
