1969 Sea Ray Rebuild (and mods) [SPLASHED Sept 2017]
CrazyFinn
And it runs! The carb rebuild I did after the initial splash last fall sure made a difference. Starts and runs like it should now! Amazing how much of a difference it makes when one of the main jets isn't completely clogged...
BlueBeard70
That's an amazing transformation. I'm going through the photos for ideas but I'm really inspired by your work! WOW
CrazyFinn
Thanks! Now I'm hoping to get inspired to actually get going on my bigger boat this weekend... After I finish re-wiring the dash on my dad's '49 Willys.
Woodonglass
Looks like that 15-91 did the trick for you. You can actually get #19 needles for it and that will allow you to use #69 Polyester thread. I still have 2 of these machines and use em almost every day. My walking foot is nice but I still like the Singers for small quick jobs. Once you get the tensions on the bobbin and the upper thread figured out, they'll sew thru 4-6 layers of vinyl all day long!!!:D;)
CrazyFinn
Bit of a setback with this one... Was working on the other boat last week, went to move this one around, was looking things over, checked the oil, and it looked like a milkshake. Not good.
The engine was running perfectly, no issues on the hose, no issues with my low speed running last fall (with the clogged carb), but I guess the long runs a couple weeks ago allowed it to heat up properly, higher water pressures, and there seems to be a crack in the block. Engine is now out of the boat, and I'm looking for a replacement.
Thinking of dropping a V8 in there instead of the 4 banger while I'm at it.
And if it wasn't enough that I have two boats to work on, my son had me help him drag home an old Vette to restore. That will be a complete body off project... Give me something to do in the winter when I can't work on the boat outside I guess...
oldrem
Had the milkshake on my Mercruiser 888 years ago. Turned out it just needed new manifolds and risers.
CrazyFinn
It has a new riser, manifolds and cylinders are dry inside. New head gasket last fall. Wish it was something like that, but it isn't. Crack near the bottom of one of the middle cylinders... It's done.
oldrem
That sucks
CrazyFinn
It’s been a while since I posted anything about this boat – but then again, it’s been a while since I did anything with it either.
As I mentioned in my last couple of posts, I discovered that the engine had an internal crack, and water was getting into the oil. With other priorities in life, I just decided to put the boat in the garage at my in-laws cottage after I pulled the engine out, and just kept my eyes open for a suitable engine, at a suitable price.
I did get some work done on my bigger boat last summer, and through this spring and summer so far, but I still have a LOT to do on it.
Anyway, a couple of weeks ago I came across a Mercruiser 140 engine listed online for a reasonable price, and coincidentally had almost the same amount of extra cash on hand from a side job I had done, so I went to look at the engine.
So… my original engine was an older version (unknown vintage/origin) Mercuiser 120, Rochester 2-Jet carb, mated to an Alpha 1/Gen 1 transom bracket and gimbal housing, with an MR drive on it.
The engine I ended up getting (the guy had two to choose from), was 140 from a newer drive and had rear mounts and exhaust riser that wouldn’t match the existing setup in my boat. He did have an older 140 that would have been a drop-in, but showed evidence of previous crack repairs in the water jacket. The engine I bought looked solid, no evidence of damage of any kind. It started and ran on his shop floor – although we didn’t run it for long with no water supply, and indoors… I knew that all of the 120 and 140 Mercruisers are based on the same basic block, and since I had a complete running engine at home (with a cracked block), I figured there would be no reason I couldn’t make it work somehow!
So – I brought the engine home, set the two engines side by side in the garage, and started working on making the new engine fit where the old engine had been.
New engine on the left, old one on the right...
First, I removed the exhaust risers. They weren’t interchangeable – the mounting hole spacing and water jacket holes were all different dimensions.
So, I decided to tackle the rear mounts that are part of the bell housing/flywheel cover. The coupler was also different. So was the flywheel. So I removed all of those from both engines, and swapped the flywheel mounting studs from the old engine to the new engine (the crankshaft holes were the same). Installed the flywheel, coupler, and cover with mounts. That was fairly straightforward.
Back to the riser problem…
The manifold on the old engine was fine. The exhaust riser was new. The carb had been rebuilt. So, I figured I would just swap the whole manifold. I unbolted both manifolds, and discovered that although the bolt hole spacing is identical, the 140 had larger exhaust ports that the old 120 manifold wouldn’t cover. Great.
So, the only thing to do was swap the whole head. Ordered a new head gasket for a 140 (3 litre) Mercruiser, and the 120 head bolted on no problem. Installed the manifold and carb from the 120. No problem. The engine would now fit in my boat.
This is what oil looks like with water mixed in...
I also swapped in the ignition from the 120 (I had upgraded to Pertronix), and also installed the new alternator I had put on the 120.
Then I discovered another issue – the 140 came from a boat with power steering, and had a thicker pulley on the water pump with two extra grooves. That pulley was going to interfere with the different cooling hose routing from the 120. So, I had to swap the water pump as well (the pulleys between the pumps weren’t interchangeable).
Anyway – it all eventually fit together, I got the engine in the boat, and as of this past Sunday it is in the water and running just fine. And the oil is staying clean!
This was my view last night when out for a cruise with my wife.
