Hi all,
I had a funny thing happen to my 25 hp yesterday. While in cruise at full throttle, the exhaust note of the engine changed (got loud). Sounded like an exhaust leak into the cowling. There were no noticeable change in RPMs or power (kept plugging along). When I throttled back to idle, it went back to normal, and and then stayed normal up to at WOT, until it again suddenly started being noisy again. I popped the cover off, nothing to see there and no obvious exhaust leak. It kept doing that off and on, and sometimes would persist even when I throttled back. A couple times when it was doing this at lower rpms, when I opened the throttle, the rpm's would increase, but no acceleration. The exhaust leak thing seemed to only start to show up after a few minutes of WOT running.
My thoughts are, that maybe there is an exhaust gasket under the power head, above the leg that is just on the verge being totally bad. When it gets hot, it starts to leak (?). As for the rpm jump, I'm thinking it might just be a coincidence that the prop has spun at the same time (?) It is a drive pin kind. It seems a bit odd to me that it can push the boat fine 99% of the time, but only slip a couple times. It only "slipped" when the engine noise was loud, not when running normally. How could they be related (?).
Compression test is great (120+ on each), it was pumping water the whole time, and no, there were no weeds on the prop (I checked).
Any thoughts? Thanks in advance.
