1970 Astro
pbeck27
I have a 1970 boat with the Astro logo on the side. I am trying to get pictures or just info on it but when I get in 1970 astro boat it states Astro didn't manufactor boats in 1970. If Astro is the manufactor does anyone know what the model name would be. I love clean , sea worthy boats and I want to keep it original but can't find needed info. placard states decarthu Indiana. Any help if with be awesome. I purchased it in PA.
without paperwork, its a yard planter.
briangcc
Looks to me as if a carpenter got ahold of the boat and trimmed it out with a ton of wood accents.
pbeck27
Yes it has the title. It just said 1970 Astro... For the person who said something about carpentry. 8 just saw a 1972 Searay, same color, same seats , same dash, I thought it was my boat but most i.portantly same wood trim as mine
pbeck27
pbeck27
Same color as mine, same seats and same wood trim. So i believe that the wood was original to the boat. I got a lot of real nice comments about my boat I. It's almost pristine condition and I feel an old boat is just as important as someone restoring an old 55 Chevy and that what I am hoping to get from this forum.
pbeck27
I just found some info. Apparently they where used as a police boat. It has the same placard and Astro logo on side of boat.
airshot
Be prepared for rotten wood under the floor, stringers, transom and floor will need replaced, as that boat is almost 55 years old. While they may look cool, those old tri-hulls were terrible for rotting under the floor.
briangcc
With all that extra wood trim on the transom and under the cleats, I would not be shocked if a total redo was in order.
A manufacturer wants to get the boat out the door asap to maximize profit. All that wood trim on the motor, under the cleats, and tacked onto the transom defeats that purpose.
pbeck27
Boat is in great shape, had it in the water several times this summer. Was told it was garage kept, never put a cover on it kept in a temp control unit.
airshot
Hope the prior owner was truthful and your boat is solid....however an inspection is in order. You need to access the wood frame and be sure it us solid. You and your guests lives may depend on it. Even as simple as drilling a small hole from the inside into the transom and stringers without going all the way thru, will let you see the wood chips to see if they are wet and rotten. Hope your is solid, but far better to be safe than sorry !!
pbeck27
Did that, drilled holes in the transom, came out clean.. it is a. Solid boat. You guys just don't want to believe it
airshot
Hope your right...those are extremely rare, especially that age ! Just shows that exceptional care pays off !
