Just bought a boat with this engine on it, owner had problems with the starter, took it home opened up the starter and water poured out of it. Ran well with the muffs on it. Took it out on the water yesterday idled rough, and when I gave it throttle it would stall out. ran for a bit with the fast idle engaged, finally got power and put the fast idle bar down, wot only gave me 4000 rpm. boated around for a few hours like this. then on the way back engine wouldn't go past 2000 rpm at wot. as we were coming back to dock the engine would increase power in 2 shots, one to 2500 rpm then to 3500 rpm. got near the dock shut off the engine, and wasn't able to start it for 30 min, finally got it started playing with the choke and fast idle bar. Took it home and opened the sparks, number 3 is spraying out a big mist of water, take off the muffs and the water stops spraying. What should I check for first?
ps sorry for the long post
