Re: 1970 Mercury 1150 - The story continues (Pictures)
the pointer can be made from a coat hanger wire or any other fixed obgect.<br /> take a deep breath and relax.<br /> the objective is to mrk the flywheel(a moving part) to a known non moving part. from there its simple matter of math.<br /> once you find TDC with a dial indicator, make a ponter or a paint dot on the block( finger nil polish is wonderful for this) this will be called TDC, from here you have several options.<br /> one is to find the ,in your case, .462" BTDC with a dial indictor and make a mark on the flywheel directly oposite the mark you made on the block or use 12" dil caliper and measere the diameter of the flywheel, multiply the dia times PI and divide that by 360 to find the thousanths of an inch per degree of circumference.<br /> I think the formula is 2xDxPI = circumference it may be DxPI=c. its esy to find on the net.<br />math and polar beer in venezeuala gets a bit difficult
.<br /> dont get hung up on covers and pointers. remember the objective.<br /> the objective is to referene TDC of the crank/piston, the easiest spot is on the flywheel, with a non moving point someplace in space.<br /> then make another mark on the flywheel that corresponds to degrees of crankshaft rotation. its basic math once you locate TDC and make a mark on the block and flywheel at TDC then do the math,cut a strip of paper the correct length ,lay the paper strip along the circumference in the same place you measured it and make another mark for total advance.<br /> for the ake of simplicity lets say your flywheel is 360 inches in circumference. divide C(360") by 360 and you get 1.<br /> that means each inch of circumference equals one degree.<br /> to get a bit more real. we will say your flywheels circumferens is 28" divide 28 by 360 and you get.078. that means each .o78 equals 1 degree. say you need 21 degrees. multiply .o78 by 21 you get 1.638. now cut a piece of paper that length. using the previous mark we made on the flywheel lay it along the previously measued circumference and volia, your now at 21 degrees of movement from the last mark. just remember you must lay the paper on the same circumference you measured or there is more math involved. you can use the thick portion of the flywheel od or the teeth just whatever plane you measuere the circle is the same plane you lay your paper and make your marks.<br /> remember the pointer is a reference, if you can garuntee you park the boat in the ame spor a mark on the wall will suffice, but a point that does not move on the block is eaier. after that we just wish to know another reference on the moving crank where is the piston at TDC then if you desire and have a lot of patience you can make 360 marks on the flywheel for each compass degree.<br /> am I any clearer ?<br /> the polar is killing me but its oh so good and only 50 cents a bottle
