- Jul 23, 2011
- 52,425
Back to my frankenmerc 9.8 electric start short shaft. (I found a running short shaft and running electric long shaft and am playing musical parts)
have the lower anti-cav plate welded up on the foot. need to sand down the lower and mid section and repaint. looks like PO had rattle canned the leg every time there was a scratch or chip in the paint. good news is the aluminum is in good shape. bad news is there must be 5 layers of paint over it, including 3 variations of gloss
will strip off all the paint to bare aluminum and start over with a good self etching primer
ordered new water pump kit for it. Sierra 18-3447 because I have the less readily available .438" diameter shaft :facepalm: (read that as 50% more expensive than the pump kit for the .456" diameter shaft.
new leg to cowl and powerhead to cowl gaskets coming as well. damaged a few things when I pulled the power head off that I need to address. thank god for fleabay as parts are available.
Pic as I started to pull parts off each motor
Pic just prior to the Admiral going WTF
short shaft mid that needs to be stripped. Clamp asmy will probably be bead blasted.
