Blake Hearn
- Feb 14, 2010
- 34
My 18hp Evinrude is not cooling correctly. It lets some water through and the water pump is new but it is still not cooling like it should. I really need a diagram of the cooling system as far as where the water goes through the engine so i can check for blockage. It does fine at low speeds but when you give it enough gas it will burn your hand when you put it to the block. The thermostat is fine. Any help appreciated.
