Sorry if this is a double post... It seems the forum deleted my original post.
I just bought an old bass tracker with a 71 Johnson 50hp model# 50ESL71S
I work with the previous owner, and his dad was the original owner, so he knows it's history and I trust what he's told me. He told me that before it quit running, it ran great. He said that for the past several years the motor quit charging the battery, then a couple of years ago it quit running (no spark). He thought it was the power pack, so he replaced that. Didn't fix it. It at least needs a new stator. The stator has a burned/melted spot on it. I'm going to replace that, then see if it will at least try to run. I don't want to pour a lot of money into it until I know it will run.
If the stator fixes it, what else should I do? I'm planning on at least: new plugs, clean/rebuild carbs, change gear oil, change fuel filter, possibly change water pump impeller.
If the stator doesn't fix it, where should I look next? Coils?
The lower unit is stuck in gear, and I can't get it into neutral. I noticed when looking through parts diagrams that it is an electric shift. How do I get it into neutral? Any ideas?
It doesn't have power trim. Is there another model with trim that will interchange with mine? Maybe I can find a used one.
The prop isn't in horrible shape, but it doesn have some decent dings in it. Where can I find a good used one? I don't really want to pay for a new one. What pitch should I get?
If I do replace the impeller, is there any special trick to getting the lower unit off, or does it just unbolt and drop right off?
That's all I can think of for now. I'm sure I'll have more questions later.
