Not quite sure where your wires go from your points but the two wire's coming off of your Stator should go to your Recitifier.Usually on your recitifier you will have 3 hook-ups top and bottom are for the wire's from stator and the center one is for 12 volts.If I am not mistaken the Stator produces 110 volts AC which is converted thru the Rectifier to 12 volt DC.That is the way it is on my 1971 Merc. 80 hp.There is a link on one of the threads here that will give you wiring diagrams of your setup.I hope this helps somewhat.I would offer more help but I am trying myself to get mine back to factory setup.Good Luck![]()
