Re: 1971 Tom Sawyer (The newest to the family)
I'm planning on doing a daily update on here with the restoration that is being done to the boat. Sadly there is no promise cause I have to do the work outside with no garage so weather plays a huge part in restoring the boat. I'm actually planning on next weekend getting started on the rebuilding process. We are expecting rain the rest of the week, and I really don't want to start tearing apart the boat till it is dry. Below is a list and the order that I'm going to do things when restoring this boat.
- Pull out seats
- Pull floor
- Multi test spots on stringers for rotted wood
- Pull stringers/replace if needed
- Pull foam/replace if needed
- Pull gas line/tank
- get tank cleaned out
- Install a new fuel line running back to motor
- Change what electrical needed replaced
- Install new floor
- Build and install sun deck
- Build and install bench seat
- Install port and starboard seats (single seats)
- Replace gauges
- When I think of more things will be added, and steps may be changed.
Below are a couple pictures of the seats I'm thinking about installing in the boat. Let me know what you think will work best with this boat.
I'm not really big on the white seat, but the interior of the boat will be a blue/white color, and the exterior will be white with some smaller colors on it from graphics that will be put in place. Now the gray seat does look to be more comfortable, but I can always change the interior color to work with the seat if the darker colored seat gets the vote. Which then it would be a dark gray/light gray color on the interior. The floor will NOT have carpet. It will be a non slick paint that will be put in there. The carpet just holds water for to long, and it will start to mold after a while. Paint can also add life to the floor as well, and easily patched up if needed. Now if the interior colors get changed to the gray then I will paint the outside of the boat a metallic black color, because I would want the boat to stay either dark colors or light colors. Now if anyone knows of some good seats that would work with my boat better than the one's I put on here please let me get a link. That style seat is what I'm wanting in the boat though. The back to back seats are being removed and not being put back in here.
Also to add in with the bench seat. One side will have a built in cooler built and installed with a drain, and the other side will just be a storage area for life vests and what not. The floor under the bench seat will also be sunk in about 3 inches deeper to give just a little bit more storage space in it which will mean the stringers right there will have to be cut some, and I'm going to add a little extra stability under the bench seating to help support the weight a little bit better.
