1972 Chieftain MKIV 25 footer ver 2
Sc25175
Re: 1972 Chieftain MKIV 25 footer ver 2
Second coat went better. Bumped up the temp in the shop and used a smidge more reducer.
jasoutside
Yah, that looks nice!:encouragement:
GA_Boater
Second coat is lookin' good!
Watermann
Looking fine to me Steve, you should be a pro painter after shooing that acre of tin!
InMotion
That looks sharp Steve! Nice work man... just think how nice that will look with all the nice shiny bits put back on!
Keep it rollin'!
Jim
barato2
what can i add that the others didn't? glossing up very nicely!
Sc25175
Topsides are DONE!!!!
The final run, all taped up final sand and paint.
GA_Boater
Good news, Steve. On to the hull. :)
jbcurt00
Wow, looks great & now that the fore deck is bright white, man that's some dark tinted windows...
Looking good all taped up for the hull paint.
Watermann
Very sweet! :encouragement:
barato2
no kidding, that's the Men In Black Navy.......:cool:
Sc25175
Thought I would show some progress
I have sanded the sides and etched them with acid wash.
Started first coat of primer
First coat of primer finished
Watermann
There ya go, making forward progress again! :encouragement:
I think the primer and painting stage is one my favorites, it means no more sanding in on the horizon. :D
bob johnson
do you have any pictures of the bracing you built to strengthen the transom for that big outboard on a bracket?
bob
Sc25175
Brand new transom, 7 inch channel aluminum. Vertical brackets through bolted to transom and bolted to existing stringers, all rivits redone with high strength structural rivits.
Watermann
Lots of nice sturdy work there but it sure looks odd not seeing a keyhole.
