1972 evinrude 65 hp shifting issue
Re: 1972 evinrude 65 hp shifting issue
Shift piston is stuck ( can not fully go into forward ) due to debris working its way into the piston bore.------Lower unit must come apart for inspection.
bass1973
Thank you racerone I will try that . Is there a way to try to clean the piston without removing the lower unit . I read someone saying useing ATF fluid . Does this work ??
????---Don't bother looking for shortcuts !----Did I mention lower unit must come apart for inspection ?
bass1973
Thank won't do the short cuts . I will remove it what kind of things should I look
eavega
catfishmatt, you should start a new thread for your problem rather than hijacking this one.
-E
