1972 offshore rebuild
Watermann
Nope, just paste it in the body of the message below your text is fine.
Watermann
Oh I see what your doing, not the URL in the address line, on the PB page look to the right, there will be a line to copy that says image URL.
GA_Boater
Cowherd - You get a Gold Star! :thumb: :D:lol: I'll be glad when the forums get back to normal.
You can put up to six pics or smilies in your posts.
cowherd
This is the power plant donor that I bought for $900. 85 Baja with a 85 140 hp evinrude
cowherd
The motor has not ran in a few years. when I got it home I put gas and a battery in it. It fired right up sounded good idled good water pumping good. After I shut it down I noticed this oil smells like gas just wondering if it is normal
Watermann
That is premix gas and oil mixed with carbon running out of the exhaust. Very normal for a motor that hasn't run in a long time. I hope you fogged the motor good before running with dry bearings and cylinder walls.
cowherd
Did not fog motor po said that it was professionally winterized three years ago. And we sprayed wd in cylinders and cranked it over before the compression test. Po guaranteed the motor as my tester had a leak and couldn't get an accurate test, but seemed to all be good.
cowherd
Have donor completely striped. Having trouble getting rid of it . Transfer station won't take it unless it is cut up. So I give that a try what a itchy mess. Anyone have any ideas?
GA_Boater
Try giving it away with a free boat ad on CL. You might hook a fish. :smile:
