Re: 1972 Starcraft Nova 18'
Thanks, GA, it helps to get some reassurance on a first time project like this. I appreciate the help. I did a transom on a 15' aluminum boat (outboard of course) and it sure didn't take much to get a hole misaligned. I think I drilled a few holes for the through bolts and then took the wood out for some reason, and then they didn't line up when I put it back in; it was a bit frustrating. I'm trying to avoid that kind of situation with this transom. I think I will drill the six holes around the keyhole and maybe a few of the through bolts to hold it in place, but the rest of the through bolts will have to wait until the wood is in the boat for the final assembly. Hopefully 5200 will be a good enough sealant around those through bolts.
I got some spray paint on the outside of the aluminum transom skin. It took one regular size can of spray paint.
The transom plywood is still clamped and drying in my garage; I got it glued last night. I think I will unclamp and finish cutting, drilling, and sanding it tomorrow. Hopefully it is dry by then.
I know there are a few places to buy parts online. What do you recommend? Mercstuff.com looks like they have the right stuff, and they are only a few hours away here in Michigan. I need the transom seal, an exhaust flapper, gaskets/o-rings for the exhaust pipe, and probably a few other things. I am going to take a second look at the bellows, but right now I'm leaning towards waiting to do that maintance until after I get the boat in the water for the rest of the summer. I tried poking a finger through the bellows, and they didn't give. I might try to inspect them with a flashlight and see if I can find any cracks; hopefully I can wait on replacing them. The gimbal bearing also seems fine; I will probably wait on that. I have also thought of replacing a few hydraulic trim lines, but may wait; the trim was working before, and I didn't notice any leaks, so why mess with it. The two lines the go from the trim pump from the inside of the boat look a little rough, but they are working now. I'm also concerned about the lower shift cable. It was shifting a little rough before, kind of stalling out, but again, I may wait. I haven't tried to adjust it, maybe that is all it needs. As you can tell I'm anxious to get the boat in the water. I'm not really in the full restoration mode at this point, more like repair to safe and functional condition. However, I don't want to be cheap or stupid and get myself into a bad situation on the water. I'm sure I will continue to fix it up down the road; I can tell it is kind of addicting already.
The last pic shows two holes from where the old depth finder was fastened with what I think were sheet metal screws. I'm wondering if I can fasten one of those transducer mounting plates/boards in the area. The new transducer will have to be mounted somewhere, maybe I can use the old holes.
