captainnate
- Apr 19, 2011
- 210
Watermann,The vinyl glue I use sticks to cured Helmsman Spar which is urethane. If the OTF is not gassed out leaving only the solids adhesion won't happen with paint or adhesive.
Which sheen do you use for the Helmsman Spar? Gloss, semi-gloss, or satin? I think I will put a final coat of this over the deck plywood.
