1973 115 Merc. still no fire
preacha
Hello again , I heard this engine run on a bench and now it won't hit bit. I replaced the distributor housing (CDI) and did the test from the CDI web site. How can I test the coil and switchbox to see if it is good? According to the CDI website it could be either coil or switchbox. Any help would be appreciated.
Re: 1973 115 Merc. still no fire
The coil may be ohmed out. Thee are specs, likely on the CDIElectronics.com website, and in a Merc service manual.
After you confirm the coil is good, check the power supplied to the switchbox, and recheck the ign circuit as in the troubleshooting test.
Gomer50
MERCURY BATTERY-POWERED CDI TEST FOR DISTRIBUTOR MODELS
This test is for the 332-2986 switchbox used from 1967-1978 on all the inlines.
This test assumes your coil is good (problems with CDI coils are rare).
DISCONNECT BATTERY
1. Turn off ignition;
2. Disconnect all 3 distributor wires on the Port side of the switchbox (and the ?mercury switch? if present);
3. Remove the High Voltage lead from the ign coil to the center of the dist. cap (remember it unplugs from the coil and unscrews from the cap);
4. Reconnect the H.V. lead to the COIL only;
5. Position the free end of the HV lead approx. 3/8" from ground (block, shrouds etc), and find a way to hold it there;
6. Jumper the brown and white terminals on the distributor side of the switchbox to each other.
RECONNECT BATTERY
7. Check that you have +12V at the red terminal (even with the ign off);
8. Turn on ignition and verify +12V at the white terminal (same side as the red terminal);
9. Ground the black terminal on the distributor side of the switchbox - this should cause a spark each time you touch ground.
If you get spark with the distributor bypassed, and it won't fire with the distributor connected, the trigger is bad and the entire distributor housing assy must be replaced.
If you get no spark using the test, the switchbox is probably bad. In that case, be sure to check for correct power on the switchbox, check all connections, and check the coil's resistance to make sure it's OK."
