Coastal Rick
- Feb 14, 2010
- 30
I got a boat and this motor about 2 months ago. The first time I fired it up in a barrel of water, it ran pretty smooth, the neutral warm up lever (it has controls) worked fine to rev it slightly just to know it worked fine. I let it run for about 15 minutes and it settled into a nice slow rhythm. I tried it in gear fwd and rev, both seemed to work great.
Next I launched it and it seemed to run just great. I was thinking what a super little outboard although it is the only one I've ever owned, being new to boat ownership. So I putted around for about 30-40 minutes from idle to wide open, no troubles. On the way back to the dock, it started to cut out and almost stall, then picked back up in a few seconds, run ok for about 5-10 seconds then power down again, and did this until it died. I got it restarted, and back to dock. If I ran slow, it seemed like it wasn't affected as much. At the dock I realized I had not opened the fuel tank valve and guessed that I was starving the Merc causing the problems :redface:. Could that cause a permanent problem for my outboard?
I launched it a few days later and this time (valve open
), it was hard to start, when I got it going it seemed to run ok but after about a 3-4 minutes it began cutting out like before and died. I could get it to start but it wouldn't idle up with the warm up lever, only run (roughly) about 5-10 sec then die. It did this about 5 times. So I hooked up the electric trolling motor I brought along and took it back to the dock.
Any ideas of where to start to get it going? I looked for a Mercury service manual but didn't have any luck, so I bought a Seloc manual off iboats and should have it in a couple days or so. Thanks.
