1973 SRV 220 OV Resto
mrdjflores
Re: 1973 SRV 220 OV Resto
toe is throbbing and aching....but tolerable...
hopefully we'll grind tomorrow, and get the tabbing in
mrdjflores
today's plan:
grind on hull, fillets and transom...
tab around the transom with 8" of 1708....4" on transom x 4" on hull
precut full transom sized layer of 1708, but making it 8" bigger along the hull sides and bottom for overlap
may get that piece resin'd in place too...not sure yet....get's dark way too early these days
Woodonglass
I know 1708 has CSM on it but...It's very thin, and OOPS tells me that he believes you get a fail proof lamination if you put down a layer of 1.5 CSM prior to the 1708. Not saying you have to, just reporting what I was told and what I do. How's the toe??
GT1000000
I wouldn't suggest you grind and tab the toe in just yet...:rolleyes:...:facepalm:...
Hope you are feeling better...:)
mrdjflores
Toe is feeling much better, i think....keep it immobilized most of the time so i dont feel much of anything.
didn't get to do anything on the boat until around 6:45pm....got dark about 45 minutes later, so i didn't get much done
mrdjflores
didn't get anything done to it yesterday....was dark by the time we got home from my daughter's volleyball game....
but no games or practice today, so may get back into when i get home for work, some more grinding before i'm ready to tab the transom in and lay the extra layers of glass........or go fishing :D
mrdjflores
proabably only have less than a month of cool weather before winter sets in. plan is to have the transom completely finished and the rest of the boat gutted, before i have to put her to bed for the winter. Can't find any place to store her inside and allow me to still work on her.
mrdjflores
did manage to do some more grinding yesterday.....on the inside of the hull floor and sides...from the transom moving forward just over 12"...
will clean it out tonight and try to get the tabbing down on the sides and bottom....4" on the transom & 4" on the hull...using 1708 glass (??)...or was it CSM??...i forgot....will have to go back an re-read....lol
Woodonglass
Some just use 1708 but I like a layer of 1.5 csm first and then the 1708. Your choice. Make sure to scuff with 60 grit and wash down with acetone prior to tabbing.
mrdjflores
tabb with 8" csm (4 on hull, 4 on transom) then tab again with 8" 1708 (4 on hull, 4 on transom) ??
Woodonglass
Yep, that gives the Thin layer of CSM on the 1708 a better base for adhering. Like I said, That's what I do, Not everybody does. If you have a good grind down to god fresh clean glass then you can just tab with the 1708, lot's of guys do that and it appears to work fine. I just like the extra confidence that I get doing it this way. Helps me believe I won't get any de-lamination later on. But hey, everybody knows I'm just an...
mrdjflores
how's this....(even though i only show 1 layer of 8" 1708 for tabbing, i'll be doing the CSM+1708 for tabbing)
mrdjflores
how much tabbing and cover do you do to the top edge of the transom....i don't have alot of room there...wood transom almost goes up to where the cap joins...maybe an 1-1/2" below the cap joint
mrdjflores
didn't get to do much of nothin on the boat yesterday...:(
between work, my 8 yr old's volley ball practice and my 11 yr old's volleyball game....didn't get home til after 9pm...
will be a repeat tonight also...:(
but can't be too sad...i love being the assistant coach on my girls' volleyball team, and watching them play ;)
GT1000000
Time spent with Family is always more rewarding than anything else we endeavor to do in this life...:D!!!
jbcurt00
Time spent with Family is always more rewarding than anything else we endeavor to do in this life..!!!
Wait, you mean to tell me that you participate in the girls recreational sports, and they don't return the favor & fight over who gets to use the good grinder while working on the family boat when you get home from a game?
A family that resto's a glasser together, stays togeth.... yeah, never mind :facepalm: Itches together maybe ....
mrdjflores
i think i'm dangerous enough around the boat...toes, fingers..(yeah, had a mishap with the grinder the other day)...so i prolly dont wanna put power tools in their hands...
although, they have come in handy when i left something up in the boat and i don't feel like climbing up into the boat to retrieve it...i just lift them up ontop the cap and get them to get whatever i left in there
mrdjflores
Not really a good day to do any glassing right now...so i figures i would tackle the belly tank and try to get out...
tank still had about 20 gallons in it, so it took awhile to get it empty...well...mostly empty.
after some gentle coaxing....finally came free....
mrdjflores
got about half of the gas tank sand down and cleaned up...i can hear a metal tube or somethign rolling around in the tank, i think it is the fuel pick up tube. Will have to cut an access hole in the top of the tank for some investigation. btw...56 gallon tank
also managed to dress up some of my PB fillets on the transom, had to go back in a couple places and add some more.
will sand them out today and hopefully start on my tabbing
