1973 SRV 220 OV Resto
Jojo54
Re: 1973 SRV 220 OV Resto
Hi, I got a 1973 searay srv220 weekender have exactly the same fuel tank and I pulled it out from the boat to check for any leak and cleaned it and I have to replace the rotten flooring ply that covers it , my question is do I have to apply adhesive glue around the edge of the plywood that covers the tank or can I just screw it for easier dismantling in the future thank you .
Woodonglass
mrdjflores, has not been around for a couple of months so I'll step in and answer just in case he doesn't. If it were me I'd want to seal the seam with something. Either 3M 4200 Marine sealant which is semi permanent or mix up some Polyester resin with some cabosil to thicken it to the consistency of mayonaise. I would not want there to be a void that would allow water from the deck to flow down below. Hopefully it will be YEARS before there's a need to go below deck again.:)
mrdjflores
+1...what he said
Woodonglass
Well,well,well,Look who's back!!! Glad to see you sir!!! The forum has had a MAJOR UPGRADE and it's NOT doing very well!!!! Be Prepared for some glitches!!!!:eek:
mrdjflores
i've noticed....i would get in and fix their system, but not sure if they would appreciate me hacking their system
Woodonglass
Yeah, I've thought about that too! If I took this long to fix a system at work...I'd get fired!!!! It's been 2 months and they can't figure out posting issues to a web hosted data base!!! Hmmmm??????
mrdjflores
Hopefully, after the holiday weekend next week, most of the projects around the house will be finished and it will be back to boat mode
GT1000000
Then again they might appreciate some outside intervention...:whistle:
Looking forward to any pending boat progress, just be careful with the old injuries...;)
mrdjflores
almost 5 years since i've started this project....don't think i've really done anything to the old girl all year....everytime i think about doing some more work on her, i begin to think how much of a pain it is to just climb up inside her...
jigngrub
Maybe it's time to pass her on to someone more able to finish her up?:grumpy:
kcassells
Or maybe it's time to get a friend involved and cut him in for a pc. of the boat and wrap her up!! There has to be a Starry Eyed associate you can geterdone with in the family or neighborhood.
kcassells
Hey here's an idea. Post and see if their are Iboaters in your area who may want to get involved with wrapping up your project together. Just a thought.
52FordF2
I don't mind helping. I was thinking do you still have the old tank,and was the new tank going to be the same dimensions. We could get together to get the wood cut and temporaly fit it in place. Then if the cold hits everything is ready for spring. I'll be working on my trailer this week, but nearly all weekends are free except this weekend (at brothers helping) and any holidays. Up north on weekdays down in Louisville on weekends.
kcassells
Good for you Ford! Ya see, we really do have a Great Bunch here. I would definitely jump in too if I were in the hood. Let's get this boat on the water, "You can doit!"
Thanks alot Ford thars just so cool.
KC
kcassells
Thanks alot Ford that's just so cool.
KC
52FordF2
:boink: Drove by and checked on the boat :thumb:. Paint still looks good. Need to get together to do some grinding :hungry:. Cold weather is best for that. We could finish the grind and then start measuring wood.
Have you thought on having your seating a movable seat like on some of the newer SeaRay. Along both sides of the engine cover with the top also on level and covered. Down low as a seat or moved up for the bed section.
Just my .02.
mrdjflores
I have some thoughts in mind, going to be a U shape seating arrangement, but the sides seats will fold down out of the way when it's fishing time
as a refresher...
