1973 starcraft 4cyl inboard
Idk it looks ok to me
Last 2 are the ones that have a weak one and these are what they look like
  • 20210603_165859.mp4
You just got this thing. Do yourself a favor, give the thing a complete tune up. Plugs, wires, cap, rotor, points, condenser. Get a new inline fuel filter for the carb inlet and replace the fuel water separator filter, hopefully you have one. Start fresh with it. Believe it or not, years ago, before cars had fuel injection and 100,000 mile spark plugs, tune ups are part of routine maintenance. This isn't throwing parts at it, its maintenance. Make sure the firing order is right, point gap and dwell are correct and timing is correct. You can't tell by looking at it.
So cleaned sparks and it did. crank crank bopbop crank crank. Now it's craaaaaaannnnnnkkkkkk craaaaaaaannnnnkkkkkk so maybe my starter is bad to?
OK I called a shop to see if they can see what needs to be fixed and all and I'm gonna see how much parts are for it
stop
service your points, or pay someone to service your points
pull your carb apart and service your carb, or pay someone to service your carb.
turning the screws does nothing if the needle and seat are stuck open.
also, if the clear tygon tube has fuel in it, you need a new fuel pump.
Took carb off cleaned or I was running lean cuz the last guy put it there so changed it back will update you guys in am goodnights
