1973 Starcraft Nova 15' rebuild
Gibbles
Re: 1973 Starcraft Nova 15' rebuild
Most of the dent pulled
Pulled rivets to get under the I guess hood, I got that looking better.
Gibbles
dents on the side will require me to remove rivets in order to get under a rib... so I doubt I will worry about those.
I removed any dents I could get a hammer on, including a bunch on the bottom :D
Gibbles
Thanks!
One thing I need to figure out: the rub rail channel...
It's too complex to get straight enough to make running the rubber back through it smooth.
The curve makes it tough to make my own cover doing away with the rub rail...
There are some metal supply places not too far away from here, they also offer bending and a fab shop.
If they have something and can match the bend from the good piece I'll replace the whole thing, but it will prob be expensive with my luck. :(
jasoutside
That's a bummer, super tough piece to replace!
I might have something here on hand left over from one of my other projects.
Post up a profile shot and I'll see what I got:)
dozerII
Moning along, Gib nice job on the dent, that is a tough spot to get at.
Glen
Gibbles
Sure np
and thanks!
Glen
Thanks
It still needs a bit more tweaking, but it looks much better.
I also found that I'm missing most of the windshield bolts, so I'll pop that off soon and possibly take the entire hood off of the front to clean it up better.
A bunch of the rivets are loose anyways :)
CheapboatKev
i've always thought if my rub rail was wasted, I'd use 1/4 or 1/2 inch rope that was sealed..Give it that old old time look..
Gibbles
Big issue is the rough cuts abd rivets that the rubrail channel covers up :(
barato2
i think he may have meant leaving the rail in place to help locate the rope and using biiig rope, like 1" to fill/hide channel. ??
Gibbles
Finally figured out where the wife put (lost) the camera :D
I hope this is what you mean, if not let me know.
thanks!
jasoutside
Well, I was kinda thinking the profile, but, I know I don't have that much here in the garage. I think I only have a couple of scrap pieces, sorry man!
Gibbles
Thanks!
And even a scrap piece I could use to replace the damaged part
No issues with cutting the end off and having the welder tack the piece together ;)
I'll try and get better pictures
Gibbles
Jasoutside,
Hopefully this is what you meant by profile picture... :)
jasoutside
I looked the other day, I think the only stuff I have left is from Jet Star interior rail which isn't quite the same. Sorry bro:(
Gibbles
no problem, and thanks for looking :)
