1973 Super Sport...I bought it!
jbcurt00
Re: 1973 Super Sport...I bought it!
Brazillian redwood is ridiculously heavy, but very tight grained, moisture resistant. And expensive. So even if you don't end up using it on the SC, go get that lumber! W/ 24 8' planks you could do some consoles on the SC & still make a bad arse table top w/ the rest:cool:.
Is it full 3/4" tongue & groove stock, w/ the relief cuts in the back. In a 4" wide plank there should be 2 saw kerf width cuts @ 1/8" +/- deep in the back side of each plank running along the length of the plank. These help to minimize cupping as the moisture levels of each plank change. They should be left intact if possible. It will have some color variations & will rapidly change colors in the sun.
I agree w/ InMotions thoughts that as a deck it may be a challenge to seal & maintain. Esthetically speaking the planks should run the length of the hull, not across the width. To run 8' planks the length of the hull, you'd need to come up w/ a whole new stringer system to fully support the staggered joints to get full length of the deck. As you have already installed a ski pylon, I would probably plan an in deck ski locker and do the hatch in the Brazilian redwood, rather then the whole deck. W/ such a tight grain & needing to be well sealed w/ epoxy, the deck might be slick when wet unless you add some sort of anti skid granules, but that wouldn't look great IMHO. But a ski locker & some wooden consoles would look really good. In lieu of the whole console, perhaps a surround for the gauges, a glove box door panel, or both dash panels.......
Well sealed w/ epoxy, UV protected w/ spar varnish, and well maintained, it could be an incredible looking addition to an already nice looking SC. Check InMotion's thread, he's doing interesting & fantastic looking work w/ wood on his SC too! The drop down at the steering wheel at the dash is really great looking.
barato2
get the wood ASAP. sell it to luthiers, who will pay a fortune for it. braz rosewood is the holy grail of tonewoods for back and sides. it is no longer available except through stuff like this or recycling. it is absolutely wasted making it into flooring, and you can make enough $ to pay for your boat. check out the pricing on the far inferior Indian Rosewood:
http://www.lmii.com/CartTwo/thirdpr...ameProdHeader=East+Indian+Rosewood/Palisander
heyyou325
bunker your boat looks great. Wished mine looked half that good. Almost finished with the second paint job on mine, and it still don't compare.
bunker108
Thanks fellas!
Barato I will call them today...seems like kind of a waste using that wood on the splashwell and for the speakers. Oh well.
I got a few accesories for the boat. I added some cleats miship and got some struts for the bimini top.
going back and forth about selling this thing...I am going to let the wife decide this weekend.
GA_Boater
Glad you decided to keep her, Bunker. Dang - she is one good looking SuperSport.
JD in Milwaukee
That is a really nice looking boat. You have done a tremendous job with it. It's begging for a repower. You'll still be money ahead.
catfishr1
Howdy Bunker ; I too am glad you decided to keep you're
Supersport. Have no idea what JD is talking about needing a repower? Are you having problems with your outboard? Or does he dislike Mercury outboards? You have indeed done a fabulous job on your Supersport & trailer. Your post are inspiring. Hope you & yours are enjoying that beautiful sunshine.
bunker108
As some of you know I have been on the hunt for a repower...but good outboard power is hard to find. I offered a fella on Craigslist $900 for a nice 1981 Merc 150 V6 with controls and trim. He simply laughed at me. I was going to offer another guy some hard earned money on a good looking Merc 1500, until a compression test revealed #3 was low.
So I decided that my money and time would be better spent opening up my current 1150. I just rebuilt the carbs, my controls have been rewired, I just got new trim hoses and I just added the trim pump this winter so I figured I was better off working with what I have.
InMotion
Bunker... makes a lot of sense what you are doing. No doubt just the re-build will give you a good increase in power. Agreed --- better to put your money into something that you know then into someone else's hands for something you have no idea about!!
Jim
ezmobee
Looks fairly clean inside with not much corrosion or build up.
ShowMeGuy
Clean up looks good. I've used a piece of glass with sandpaper to make sure everything is flat on tractor engines i've worked on. Not sure if that would follow into all of this AL metal boat stuff....
Nothing better than fixing something yourself and cheaper while knowing just exactly what you have when you are done... Vs. the roll of the dice on something used/new to you.
barato2
are you sure it isn't worth doing at least new rings and quickie hone of cylinders while you have it apart that far? but i like your plan overall, i always prefer a known 30+ yr old mech assy to an unknown one
bunker108
Thanks everyone. Yes barato I probably should just tear it all the way down but the cylinders, pistons and rings look ok from what I can see of them. Plus I don't want to tear into the crankshaft side of the engine. And plus with the blind bore design of the Merc inclines the crank and pistons have to go in as an assembled unit which I read can be tough without the right tools. This tear down has removed any fear of doing that job at some point though.
barato2
your reasoning makes sense altho i doubt that your power shortage has to do with gaskets as much as cylinder/ring wear. but if you got decent compression #s on it before the teardown, yeah, no reason to yank the crank
bunker108
I am going in circles with this Mercury. I got the power head back together and installed on the the lower unit. While installing it I must have kicked it into reverse by accident. The the topside all buttoned up and then dropped the LU to shift it to neutral. I have had the LU off several times and never had a problem going back together until now. Needles to say the shift cam seems to have become separated from the shift shaft. The shifter spline just spins now. Sooooooo....now I am on the hunt for a LU.
64osby
I would post in the Merc section before investing in a new LU. Might be something simple.
Good luck and nice work.
bunker108
I posted over there too and on the inline 6 page on Facebook. It sounds like a simple repair...which involves removing most of the guts from the case. I'm just not equipped with pullers and a press. I am hoping to find a working LU and slap it on there. I have had it with mechanical issues this year. I enjoy the process, but am getting frustrated going nowhere.
64osby
Puller and press
images
If that doesn't work than use this one
images
Good luck on the LU search.
jbcurt00
Yep, boat mechanics, like carpenters all need to keep a BMFH* handy for times like this. If it doesn't rectify the current problem, it can prove to be a nice stress reducer when swung with authority at something malleable.
*Big Moth#@ F@#$ing Hammer:eek:
