1973 Supersport SS16 Rebuild
budski
Thanks Guys we're getting there, now the thinking part starts, want to do a few mods not sure how yet.
budski
No Title
Testing the windshield from my 18 ss on this one works great, just have to raise the inside leg about 2 inches but it will work great.
ezmobee
Looks perfect, Getting those darn things to line up right was one of the most challenging parts of my build.
budski
No Title
Thanks Ez, we had to make the consoles 2 inches higher at the leg and 1 inch wider to accommodate the windshield, also painted the outside of the transum where we modified it and added blue foam flotation on each side.
Watermann
Hey your really getting with it! Looking like a winter splash for this one if you can find some soft water that is :lol:
budski
Thanks Rob but I don't think we will be seeing any soft water around here for at least the next 6 months.
budski
Yes Marc, you got that right, I didn't think about it.
budski
No Title
Got the transum capped, the rear deck cut out and spar varnished , started to carpet some of the inside sections.
classiccat
"Captain" + Starmada Splash Of The Year 2020
Tight execution on that Transom John! :thumb:
fetch
Watermann
Things sure have slowed down around here... except in your garage! :encouragement:
budski
No Title
We got some more of the carpeting done today.
axlr8
This is a very inspirational thing to see. Ill be tackling the same kind of rebuild but on a little different style boat. I will be using the diamond plate transom reskin like you did, the previous owner of my boat apparently changed powerheads multiple times, there are about 5 complete sets of holes back there...what thickness plate did you use? And what alloy if anything special?? Ill be using the boat in freshwater if that makes any difference..
budski
Thanks axir, I used 1/4 for the engine mounting plate, and 1/16 on the inside and transum cap, no special alloy.
budski
No Title
Got the rear deck carpeted.
Watermann
Hey looking sharp John! I see you went with the deck plate in the SW too, sure will make it easy to deal with what ever goes on in the bilge and I put my spin on fuel filter in there too.
g0nef1sshn
Your gonna love having that space on the rear deck! Im too happy i went that route. Might even make mine a little bigger now. And add that access you did but a square door for more room to reach in.
budski
Thanks guys yes those access deck plates are awesome, make things so much easier to get at.
budski
No Title
Got the latches installed on the rear access doors, rod holders and rear tie down hardware installed.
