1974 302 Holley 2barrel
Amcdaniel559
I have a 1974 302. I had the carb rebuilt about 2 months ago. Ran great for about 20 hours. Now it will start and idle great. Run great going slow at lower rpms. Get to WOT soon as boat is getting to plane it dies. Replaced all filters, fuel line, anti siphon valve, spark plugs. And still does the the same. I’m Thinking it’s the fuel pump. Also my coil gets hot, super hot. But it has always done that when running good. Want to do a pressure test on fuel pump under a load but I live about 1.5 hours from the water. Thank you
Welcome aboard
Regarding the fuel system. Check your filter, check the anti siphon valve, and check your fuel pressure
Regarding the coil, they do get hot, about 180 degree hot. That is about 30 degrees warmer than you can keep your hand on. That is normal
You should have points, make sure your ballast (resistor or wire) is still intact, and you properly set dwell and timing
Amcdaniel559
Thank you Scott.
I have been reading and it seems like the fuel pump I have will have a built in fuel filter? I didn’t know this I just changed the inline. Can I get a good reading on the fuel pressure without the boat being under a load?
Thank you Scott.
By reading you are only guessing
You need to test
Look at your fuel pump. If there is a glass bowl on it with a fuel filter in the glass bowl, then yes, you have a filter on your pump. If not, you dont
That is part of your problem. The rest of your fuel system upstream of the filter needs cleaning too
Amcdaniel559
I took the carb off, to the bowl and float apart it was really clean but I sprayed throughly with carb cleaner. Replaced fuel lines. And pumped a couple gallons of fresh gas through the fuel pump. Any other thing I should do?
Scott06
Open the tank and look in there siphon some gas off the bottom where debris will accumulate see what it looks like
