Woodonglass
- Dec 29, 2009
- 25,930
Uhhmm no one recommended Hammering anything in place. The Rubber mallet just loosens the fabric weave and allows it to conform to sharp corners. Cutting the transom edges to 45 will increase the amount of resin used. PB filler is thickened resin using cabosil and Chopped Strand Fibers. It IS very strong and will not crack. If you cut your transom 1/2 inch short all the way around then apply the PB liberally to the back of the wood the PB will ooze out around the sides and you use the excess ooze out to form the fillets. This makes it MUCH easier to lay the layers of 1708 over the entire transom and out onto the hull sides and bottom. The 2nd link below has the info. Not sure how you think cutting 45's will make it easier or stronger. Sometimes the tried and proven metehods ARE the best because those that use em have already tried many of the other ways and found them NOT to be effective or advisable. Not to say that there's not more than one way to skin a cat. Some are just better than others and you learn from your mistakes. Bottom line it IS your boat and you can do with it as you see fit.,
