1974 Johnson 40hp will not kill
Crosbyman
i hope that harness does good for you… $$$$$$
you tested 0 ohms on the blues back to the kill switch which is what you wanted
boydog
NEW harness solved it!!! wasnt that expensive, and simple to install
thanks guys!
boydog
sure! we know it was bad harness right! oem old harness
oldboat1
imo, you need to put the multi-meter in the drawer, and get a simple continuity tester -- the kind with a light, battery and probe. To satisfy curiosity and prepare for the next time around, test each of the wires in the old harness, point to point. See if there is a broken or corroded wire. Check any fuse links -- takes only a small bit of corrosion.
