MonkeyBird747
- Aug 5, 2020
- 112
A couple of questions on water in the bilge and how much, if any, is considered acceptable/normal on these riveted boats. I have an automatic bilge pump installed on the hot batt bus. After a full 8-9 hours on the water the other day i was pulling the boat up the ramp on the trailer and the auto bilge kicked in. First, it was good to know it works! But it puked out maybe a gallon or so of brown water (hard to judge, but a 3/4" stream for 20-30 seconds maybe?) out of the upper exit on the side of the hull. I had not drained the bait tank yet, so some of this was likely overflow from the bait tank drain at the top of the tank.
The next trip out the auto bilge never kicked in, and I put the boat away in the garage. When I was hooking up the trailer for the next adventure I had to rock it around to position on the hitch. When I did, the auto bilge kicked on and puked a gallon or two of brown water onto the garage floor.
The trip last night was very short at maybe 3 hours. When loading up to leave and while the boat was still on the ramp I manually turned on the bilge pump. A small amount of water pumped out, but you could hear the pump cavitating the whole time, so it wasn't completely submerged.
After the pump ran a bit I shut it off and pulled the drain plug. I was thinking that the bilge couldn't possible pump ALL the water out as low as the drain plug, but when I pulled it nothing came out. It was damp inside, but not even a trickle. So maybe the bilge pump is doing a great job.
Is some water intrusion to be expected on these older riveted boats, or should I be chasing down possible leak points? I have a few suspects at the transom where previously installed equipment bolt holes have been plugged with some type of rubbery silicone. What would be the proper method to plugging these old through-holes in the transom? I was thinking a bolt with washer and silicone on either side, but I'd have to cut out some of the rear decking to access these, and I don't really want to do that. Is there a good method to plug them from just the outside?
I was also wondering if some water is just filling up the bait tank line and being routed into the bilge later. I usually keep the bait tank plug pulled, so if some water were coming in that way it would just circle around and get routed back to the bilge. The pump should have a check valve that prevents this, but maybe it isn't working properly.
The bottom of the boat looks great to me. No signs of abuse that I can tell, and I don't see any missing or suspect rivets. Check out the pics. I don't know if there is enough there to account for that much water coming in.
