I am putting on a 4" shaft extension, the extension is used but is an original factory part. The problem is the drive shaft extension. I put it on the end of the shaft to feed it up through the intermidiate housing but the knuckle where it slides over the old crank won't fit through the entry point in the intermediate housing. I have the whole motor disassembled to get the extension inside the housing. My question is, can I ream out the entry point in the intermediate housing so it will go through? I can't imagine going through this major disassembly every time I change the water pump.
